EdiTree is a set of useful open source components developed by EDIT Collective to provide easier manipulation of data structure and data management.
It offers some additional features as follows, plus the existing data management components:
SubTree Retrieve a specific branch / sub-branches from a data tree. This component lets you extract items under the specified branch, when branch path indices are assigned.
Divide List Divide a list into sub-lists by the predefined number (divisor). Any remaining item will be stored in the separate path followed by last branch.
Partition List (Advanced) Partition a list into sub-lists by partition size. This is pretty much the same as the existing Partition List component except that it gives any remaining item in a separate list.
Split List (Multiple) Split a list into separate parts at a specified index number. Similar to the existing Split List Component, each index indicates the first item in each list.
Details and download on food4Rhino…
Posted Mar 09, 2016 by Cécile Lamborot on Rhino News, etc.
