@stevebaer and @Alain
I’m feeling tremendously stupid, because I can’t get EditPythonScript to work.
I did the following in the daily build of Trunk V6
Run EditPythonScript
Type this script:
import Rhino
d = Rhino.RhinoDoc.ActiveDoc
for object in d.Objects:
pass
I put a break point in the “pass” line.
Then I clicked the green Play button.
the EditPythonScript window disappeared
I brought it back up, and couldn’t tell what was going on. I couldn’t tell if the debugger was stopped on a breakpoint, or if it was done debugging. I couldn’t edit the text, so I assumed it was debugging.
I then clicked Stop. Nothing seemed to change.
Then I closed EditPythonScript by clicking the red X. Rhino asked if I wanted to stop debugging; I clicked Yes, and the window stayed open. I closed it again.
Opening EditPythonScript, I still can’t edit the script.
What’s going on?
