EditPythonScript AutoComplete bug
Hi @clement,
What I meant was that the line starting wih “clr” needs to stand on it’s own and not depend on values defined in other lines. So auto completion doesn’t work after
path = r"C:\Test.dll"
clr.AddReferenceToFileAndPath(path)
no matter where path is defined. Instead it needs to be all on one line:
clr.AddReferenceToFileAndPath(r"C:\Test.dll")
That’s how it works now.
In the future we want to integrate with an existing language server so you’ll get the same auto complete as vscode for example. If a problem has an acceptable work around, affects very few people, and isn’t a trivial fix then it will have a lower priority but of course otherwise we want to fix it.
I hope that makes sense.
