Editor - Referencing wrong python package directory
Hi.
Am scripting in Python3, in Rhino8.
The script uses Numpy, and worked well yesterday.
But today, after attempting a package install that went wrong (multiprocessing). The original script doesnt work anymore.
The script uses numpy, and the error I get is:
Traceback (most recent call last):
  File "rhinocode:///grasshopper/1/2ce434ae-a001-4192-9330-7f332b6c3991/ec5f1a54-5332-4f22-a0dd-93a139724fa1", line 18, in <module>
  File "C:\Users\name\.rhinocode\py39-rh8\lib\site-packages\numpy\__init__.py", line 211, in <module>
    from . import lib
  File "C:\Users\name\.rhinocode\py39-rh8\lib\site-packages\numpy\lib\__init__.py", line 33, in <module>
    from . import _polynomial_impl
  File "C:\Users\name\.rhinocode\py39-rh8\lib\site-packages\numpy\lib\_polynomial_impl.py", line 19, in <module>
    from numpy.exceptions import RankWarning
ImportError: cannot import name 'RankWarning' from 'numpy.exceptions' (C:\Program Files\ladybug_tools\python\Lib\site-packages\numpy\exceptions.py)
So it does look like it is trying to use Numpy, from the LBT installation.
FYI the header of the file is:
#! python 3
# venv: site-packages
# r: numpy
I’ve tried restarting, but it seems like my GH/Python setup is corrupted.
Any ideas on how to solve this?
I’d get rid of any multiprocessing remnants (and everything else) and force a reinstall of numpy (and everything else).
Do: cd %USERPROFILE%\.rhinocode\py39-rh8\site-envs then cd into default- whatever it’s called. Delete the directories starting with numpy to uninstall them.
Alternatively without deleting anything, you could try setting up a venv, # env: my_venv I believe, and install all the deps into that instead. But I don’t know if the globally installed packages are still importable from Rhino/Grasshopper’s type of venvs.
Thanks for the answer @James_Parrott, but no cigar (yet)!
My default directory is empty:
Directory of C:\Users\arnkepet\.rhinocode\py39-rh8\site-envs
09.04.2025  09:45    <DIR>          .
18.03.2025  13:28    <DIR>          ..
09.04.2025  09:45    <DIR>          default-9ylcYXdq
               0 File(s)              0 bytes
               3 Dir(s)  308 797 067 264 bytes free
C:\Users\arnkepet\.rhinocode\py39-rh8\site-envs>cd default-9ylcYXdq
C:\Users\arnkepet\.rhinocode\py39-rh8\site-envs\default-9ylcYXdq>dir
 Volume in drive C is Windows
 Volume Serial Number is 4C42-C52C
 Directory of C:\Users\arnkepet\.rhinocode\py39-rh8\site-envs\default-9ylcYXdq
09.04.2025  09:45    <DIR>          ..
               0 File(s)              0 bytes
               2 Dir(s)  308 796 784 640 bytes free
Is rhino using the LBT directorys for all packages?
How do i find out?
And if so, how to I direct to here?
Ahhh.
So the solution was to delete the corrupted Numpy, as you said, from here:
C:\Users\USER.rhinocode\py39-rh8\Lib\site-packages
Good to know - thanks. All the possible directories to import from can be seen on sys.path.
