Hello! I am trying to get “Editing the position” of a camera to work, and I think I’m coming across a bug or something? I am using the Designer $49/month version, so I don’t have API access, so I figured I’d just use the ShapeDiver web-editor to set the cameras. Here’s how it’s going:
Below is a picture of a camera set to a view of this arch I would like, by inputting the coordinates to the Default Target entries. a camera targeted at x=251, y=690.
However, if I open another camera, eg Top camera, and try to open that arch Camera, then the target is actually pointed somewhere consistent but random instead.
However, either method, even though the camera defaults to pointing somewhere random, if I add 0.1 to one of the Default Target values, it shows my desired view, even though it won’t save that view
Hey ! Thank you for trying! The bug seems to still be happening in the same way, I can’t manage to get a custom camera set.
Could it be because I’m setting up the camera in between objects or something? like I’m trying to get a view amongst these ‘walls’. I noticed setting up the camera works better if I set it pointing from outside all of my objects, and it gets worse the closer to my objects I set the camera.
We have been working on several issues with the camera controls and I mistook yours for one that we already fixed, my apologies. The one issue you are facing will also be solved in the next version, which we will this week. Thank you for your patience.
