I found a small bug for me
If I create text in top view
Click the text to edit it, then edit the text in the properties panel /text icon
If I click on the layers tab right after editing text
Rhino stalls and I have to close Rhino manually no file can be saved. Rhino doesn’t crash it just hangs.
Latest service release win vista home premium 32 bit.
RM
That has happened to me a few times and I haven’t been able to remember the steps to repeat it and report. I just tried this and get the same stall - no save and ctrl-alt-del req’d. It also happens after a text height change in the properties panel.
Version 5 SR5 (5.5.30619.7565, 6/19/2013) running on XP
I see that, thanks.
This previously reported crash just happened again, so a gentle bump in case it never made it to the bug tracker. Its pretty important as work is lost back to the autosave. Thanks.
Version 5 SR5 (5.5.30717.16015, 7/17/2013)
Thanks, the bug is on the pile as http://mcneel.myjetbrains.com/youtrack/issue/RH-21467
I added a comment as well.
