Why doesn’t F10 turn Solid Points on? F11 turns them off just like with 2D lines.
Thanks,
Dennis
Thanks,
Dennis
I suggested that too : )
So, you know I agree.
[I use solid points a lot for doing filleted flatwork because I can just lasso and resize the edges–without changing the fillet size.]
Well, again, it would be ambiguous under some circumstances, as single surfaces can have both normal and solid points (and they are different). And I would rather there not be special casing of these commands that they work one way for curves and another way for surfaces/solids.
I have SolidPtOn on the F9 key… --Mitch
Ah. I knew there was a good reason!
Dennis
this help? doesn’t work with preselection FYI
'Script written by Ryan Gilmore (monkeygrip@gmail.com)
'Script version Tuesday, 23 October 2012 09:49:24
'Description: Turns on points for all selected objects
'Edits:
'Todo:671200060
Rhino.AddStartupScript Rhino.LastLoadedScriptFile
Rhino.AddAlias "OneShots", "_NoEcho _-Runscript OneShots"
Option Explicit
Call AllPointsOn()
Sub AllPointsOn()
Dim arrObjects, Object
arrObjects = Rhino.GetObjects("Select objects for edit point display.", 1073742364, True, True, False)
If isNull(arrObjects) Then
Exit Sub
End If
Rhino.EnableRedraw False
For Each Object In arrObjects
Rhino.SelectObject Object
If Rhino.IsBrep(Object) Then
Rhino.Command "_NoEcho _SolidPtOn"
ElseIf Rhino.IsCurve(Object) Then
Rhino.Command "_noecho _PointsOn"
ElseIf Rhino.IsDimension(Object) Then
End If
Next
Rhino.EnableRedraw True
End Sub
