Editing extruded features
hi, I have this part I have made but realizing now I would like to change the tolerance by 0.10mm. Is it possible to still do this if the feature has already been extruded.
Thank you
Hello - what do you mean by this? I am guessing not the document tolerance. Which part of the design do you want to change? Note if you extrude curves with Hstory recording on, you get to edit the input curves and the extrusion will update. Not sure if that covers your case.
