Hatch Bug.3dm (48.9 KB)
This Rhino file contains a block with two objects: a hatch and a curve at the hatch boundary.
Double-click to open block edit, then immediately click “Okay” without making any changes. When block edit closes, the hatch shifts slightly (about 0.0074 units) relative to the block location (the curve is unchanged). Repeatedly opening and closing block edit in this way incrementally shifts the hatch more and more away from the boundary curve.
Exploding the block and creating a new block with these objects fixes the problem, and new instances of this block don’t have the problem either, so it seems to be some corruption to the state of this particular instance (the bug did survive copying this block instance from another model).
Rhino 8 SR25 2025-11-4 (Rhino 8, 8.25.25308.13001, Git hash:master @ b74710ef8645f421cc69ca4ca75ef82b0892e860)
License type: Commercial, build 2025-11-04
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.31
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX 2000 Ada Generation (NVidia) Memory: 16GB, Driver date: 3-15-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 595.95
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 2GB, Driver date: 3-3-2026 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-15-2026
Driver Version: 32.0.15.9595
Z-Buffer depth: 24 bits
Total Video Memory: 16380 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.25.25308.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp "WebBrowser"
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp "IdleProcessor"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.25.25308.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp "Legacy Rhino Render"
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.25.25308.13001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.25.25308.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp "IronPython" 8.25.25308.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.25.25308.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.25.25308.13001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp "BlockEdit" 8.25.25308.13001
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
