Edit Slab Based on New Line Outlines
Is it possible to edit the outline of an existing slab rather than remaking the slab, by passing in new linework. Basically I want to ensure if I have dimensioned to a slab- the dimension wont fall off.
I dont want to redraw rather than have to create another one.
Thankyou
Thankyou- can this be done through a rhino inside node or do I need to write some api code for this?
The node is called “Host Boundary Profile” as mentioned in Kike’s post ( You will also need v1.9+ as mentioned)
