Edit Pillar block doesn't works and Pillar not work in Octane render
I found this bug inside Visualarq last release and Rhino last release. The first thing is that I can’t edit a pillar block because of the message I receive (I send You the error message). If I try to go on and edit the pillar anyway, I can but then in Octane render I visualize the strange pillar that I send You the second pic.
Someone could help me?
Thank You,
Roy
Hi @lopez , if you draw a new pilar similar to the one in your picture, does the problem persist? can you share that 3dm file so I can check it out?
