Edit leader text in property window
If I select a leader and try and edit the text in the property window, I can type one character before the caret moves to the beginning of the line. Initial placement of the caret seems a little funny as well (it doesn’t often end up where I click on the first try). Double clicking to edit leader text seems to work fine.
Sam
That’s not good… I see what you mean. Filed as http://mcneel.myjetbrains.com/youtrack/issue/RH-28763
Stretching Leader edit window isn’t stretching the relevant text area like Text edit.
Thanks… filed as https://mcneel.myjetbrains.com/youtrack/issue/RH-39273
Looks like I missed the spot to drag to resize the leader edit text area… We’ll need to make that more discoverable but in the meantime, try hovering right over the B I U options to see the vertical arrow.
