I have a probleme with editing UDA of an item can you help me please ?
Thx
Hi, what does the output from the “Get All UDAs” component look like?
Hi Sebastian,
Here is the list of attributes, and since I had a doubt about the format of some attributes where there are empty spaces, I replaced them with a single attribute to test, but it still doesn’t work.
For your information, I’m also working on a shared model.
Ahright, indeed using spaces in attribute names is not recommended:
While it technically might work in some cases it will mess up different tools (like the GH-Tekla link… but I’m thinking you might risk interoperability as well if you e.g. export this to IFC)
Are you able to change your routines to use underscores instead of spaces in your attribute names?
Your single attribute in the last pic seems to be fine, the attributes component isn’t red any more. The error might be something else, check what the Modify component says.
Cheers,
-b
