Just a simple question I hope. If I had a square curve with a random set of points, how could I copy a circle from its center along this list of points?
So here is what i’m actually trying to move along each point. The Curve is made from a tangent between two circles that I want to array along these points.
Thanks for the idea, i thought that would work but I was wrong. So I have a curve made from a tangent between two circles that I want to array along these points. I’ll attach the file here, the parameters are on the far right named
I have no idea if this is what you want, but the Vector2pt component can be used to set a vector from point A to B, then use the Move component like so.
