Edit an Extrusion
Hi
How can I go back and fine tune the dimensions of an extrusion?
Thanks
Try to do with command “BoxEdit” It may help in simple cases
You can also for instance select the top or bottom extrusion edge/face and move it with the gumball in the extrusion direction. The gumball can do precise operations if you give it a measure, instead of moving it by hand.
For extrusions, if you use _SolidPtOn, you get two points to alter the extrusion depth/direction, while keeping it an extrusion object.
Hi Jose - Here’s a thing that may help-
SetExtrusionLength.py (2.9 KB)
To use the Python script use RunPythonScript, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
This solves my specific problem for now.
Thank you
Hi Jose -if you create the extrusion with History recording on, you can edit the input curve to edit the shape of the extrusion.
