Hi.
If you create rib surfaces using straight lines with curves using the Loft or Ruled Surface command, then
more or less, the greater the curvature of the curves, the worse the glitches will be.
This could be a workaround for you.
In the meantime I already realised that the RuleSrf was the problem, but I just couldn’t get around it. Your solution is awesome! I learned a lot today.
