I set egde thickness for render view mode to 3. In view i see big difference imidiately, but during printing there are no changes. Where is the problem? Even if I set Edge thickness on 50, print export isnt affected at all.
Edge lineweight on printing can be set in the layers panel:
Or per object in Properties:
Or, if you just want the default to be heavier, you can set that in the print dialog:
Sam
Thansk a lot!
Two questions arise for me:
In a view mode, what effect does changing edge thickness settings have?
How to set up different line thickness for the same object in plan projection, elevation projection, and perspective.
Hi David -
Since the answer to that question should be obvious - it changes the edge thickness - I am guessing there is more to this question than what you have typed…
You’ll have to use different display modes in different views.
- Under what conditions is that supposed to be visible? I am not seeing any difference either un display or printing. But there are other anomalies, with Visualarq performance, so I may need to update my display driver.
