Edge Surface Linetypes
Im trying to make a custom display mode for a project Im doing and stumbled across surface edges which seems to be what im looking for, but the lines are thick and continuous is there a way to manually change the linetypes for the surface edges with other lines?
Yes, you can apply a linetype to surface objects, which will show on their edges.
Wow didn’t realize the edge lines change along. Thanks for the solution!
