Edge selection, click and drag diagonally
Hi Is there a way to select model edges where the selection window can be irregular shapes so you can avoid picking area that you don’t need ? So far I can only get rectangle click and drag method. I would like to clink and drag in diagonal.
You could try the Lasso command in combination with the SelectionFilter set to subobjects. Note that not only can you hold the mouse button down and drag a sketch selection area, you can also click-click-click… to make a polygon area selection.
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/lasso.htm?Highlight=lasso
Thank you so much. Very cool command.
Have a great day.
