Edge Or Curve Input for a component
Hi guys,
I want to have a input in my component. This input can link to a edge on a brep or any curve like spline, line, arc, etc.
Could anyone please tell me how to do it? I have ask chatgpt, it has many suggestions, but none of them works.
Regards
Eric
Hi Eric,
We need more context here. Is this a cluster? Scripting Component? Can you share a GH file?
This isn’t really enough to go on. Are you trying to have curves influence your component of have the component extract curves from another type of geometry like a surface or brep?
Please provide more info,
Thanks
Hi Michael,
Here are codes snippet:
    protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
        // Use the pManager object to register your input parameters.
        pManager.AddGenericParameter("Unfold Vec Dir", "CD", "The Curve/Edge should be along the roughly rectangular shape of the surfaces.", GH_ParamAccess.item);
        IGH_GeometricGoo curve = null;
        iDA.GetData(0, ref curve);
        if (curve is GH_BrepEdge edgeWrapper) // here we can't compile.
        else if (curve is GH_Curve curveWrapper)
Here is the basic structure suggested from chatgpt.
What I want is a vector. I use the end points of the curve to calculate the vector. Most of the time, I need a vector calculated based on the brep edge. I want to user to select one edge on a brep. If there is no suitable edge to select, user can create a line which can be used as an input as well.
Hope I have made my problem clear.
Thank you.
Regards
Eric
