Hey everyone,
Is there a fast and easy way to change the diameter of a hole to an exact size? I’m working on a mechanical design where I have a lot of holes in a flat panel and need to resize a bunch of these holes to accommodate different fasteners.
This is probably the moment you should start working with Grasshopper
Command “modifyradius” should help.
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#commands/modifyradius.htm#(null)
The command ModifyRadius doesn’t do anything on a Round hole created with Rhino Solid Tools…
