Easy creating duplicates of an already applied material surface
Hello forum. As an absolutely newcomer to Rhino 7 I succeded in applying a Cast Iron reflective surface to a drawing.The result looking exactly as what I had in my mind.
Now I will repeat that look in other drawings. In spite of several attemts I have have had no luck in doing so.
How can I easily repeat exactly that look to other drawings ? Hope you have a hint !
Kind regards Carsten Hviid
hi @Carsten_Hviid I assume the material you have applied to the object needs a certain mapping to look right. If you can post a file or at least an image, it will be easier to help you.
