How I can do this?
I don’t find an easy solution for this simple drawing…I need help
How I can do this?
It’s “easy” and “basic”!
Can you hel me a bit?
That original image uses Metaballs to generate the outlines. You have to divide your column curves into N points, make sure all points that belong to the same height end up in the same list, then run the Metaball component with varying thresholds.
It might actually be easier if you use Contour instead of Divide Curve.
Thanks!!
