Dynamically modify command history output
Hi everyone,
I don’t know whether anyone has thought about making an animated command line output like the those we saw in DOS era.
bar-cat-n
Is there a rhinocommon feature that can dynamically modified the commond history to realize such effect?
I am working on several scripts that will take long to run. I want my user to be able to see the progress whilst not getting a long list of print outputs.
Thanks.
Use the status bar progress indicator…?
https://developer.rhino3d.com/api/RhinoScriptSyntax/#collapse-StatusBarProgressMeterShow
https://developer.rhino3d.com/api/RhinoCommon/html/Overload_Rhino_UI_StatusBar_ShowProgressMeter.htm
You can also dynamically output the command prompt…
CountdownPrompt.py (361 Bytes)
Thank you! I’ve never heard of the status bar progress indicator. Will definitely try it.
