Dynamic neon line
Hello!
How can I reproduce a similar animation of glowing dynamic lines by changing the length and material parameters of the curve or ribbon geometry?
I need to figure out if it’s possible to do this with grasshopper or if it’s better to turn to after effects…
For example, if I were to create a simple animation with curves lengthening and shortening (using a slider), pipe them and give them an emission. But the curve length parameters are negative, so unfortunately I can’t reproduce the animation.
