Hey.
I’m trying to create a dynamic list component where one list is populated based on another selection. To start off with I need to have a c# component that can create and instantiate inputs on the grasshopper canvas. I’ve managed to do this before with panel components, however I’m having issues with a valuelist component and I have no idea why. The process I used to create the panel is the same as the one here, but it’s just not getting created on the canvas.
protected override void SolveInstance(IGH_DataAccess DA)
// http://james-ramsden.com/grasshopper-automatically-create-a-value-list-in-c/
bool buildIO = false;
DA.GetData(0, ref buildIO);
if (!buildIO) { return; }
string rawStr = "";
DA.GetData(1, ref rawStr);
List<string> IOMapRaw = new List<string>(rawStr.Split(new[] { Environment.NewLine }, StringSplitOptions.None));
List<List<string>> IOSplit = new List<List<string>>();
List<List<string>> names = new List<List<string>>();
List<List<string>> values = new List<List<string>>();
IOMapRaw.ForEach(x => IOSplit.Add(new List<string>(x.Split('='))));
IOSplit.ForEach(x => names.Add(new List<string>(x[0].Split(':'))));
IOSplit.ForEach(x => values.Add(new List<string>(x[1].Split(':'))));
var pManager = this.Params;
var vlist1 = new Grasshopper.Kernel.Special.GH_ValueList();
vlist1.CreateAttributes();
vlist1.Name = "VList1";
vlist1.NickName = "VList1";
vlist1.Description = "Dynamically created list 1";
vlist1.ListMode = Grasshopper.Kernel.Special.GH_ValueListMode.DropDown;
vlist1.Attributes.Pivot = new PointF((float)this.Attributes.DocObject.Attributes.Bounds.Left - vlist1.Attributes.Bounds.Width - 30, (float)this.Params.Input[1].Attributes.Bounds.Y + 2 * 30);
vlist1.ListItems.Clear();
vlist1.SelectedItems.Clear();
var vl1Vals = new List<string>();
for (int i=0;i<names.Count; i++)
if (!vl1Vals.Contains(names[i][0]))
vl1Vals.Add(names[i][0]);
var vl1Val = new Grasshopper.Kernel.Special.GH_ValueListItem(names[i][0], values[i][0]);
vlist1.ListItems.Add(vl1Val);
var ghdoc = this.OnPingDocument();
vlist1.SelectedItems.Add(vlist1.ListItems[0]);
pManager.RegisterInputParam(vlist1);
ghdoc.AddObject(vlist1, false);
pManager.Input[2].Optional = true;
pManager.Input[2].RemoveAllSources();
pManager.Input[2].AddSource(vlist1);
When I run the build button, it creates the valuelist, input source and attaches it to the c# block (it becomes an input on the c# component, can right click it and edit just like a regular valuelist panel) but just doesn’t create on the grasshopper canvas. Any help resolving this greatly appreciated.
