Dynamic camera target (feature request)
Hi there,
Recently, I have been working in QGIS 3.28 making 3D maps. After initial confusion, I have noticed their method of camera target one good advantage. I don’t believe that rhino yet has this option. With rhino, the point around which the camera rotates seems to be static. This requires zoom selected hundreds of times a day.
Qgis creates a new camera rotation point for each time you rotate the camera. I believe it does this by:
Projecting a new camera point each time you rotate the camera. The projection occurs by: taking the current camera point, plus the mouse cursor point, and projecting that point to a surface. That point which has been projected to the surface is now the point which your camera rotates around.
Please see video from Qgis below:
Whereas in rhino, it seems that you have to zoom selected many times on an object.
What are your thoughts?
-Jeremy
Hi @jdelavaulx
Hold down ctrl+shift+rmb to use the cursor position as the pivot point for the camera.
HTH, Jakob
Thank you so much Jakob :slight_smile:
Is there a way to have this setting on by default?
-Jeremy
Hi @jdelavaulx,
In V8, you can change it in Advanced Options:
