DXF import: missing horizontal segment and unwanted diagonal
Note: This report was drafted with AI assistance and includes AI-assisted inspection of the source DXF. The behavior described was observed by me in Rhino, AutoCAD, and Adobe Illustrator.
When opening the attached DXF in Rhino, an existing horizontal segment disappears and an unwanted diagonal appears.
Both AutoCAD and Adobe Illustrator display the same DXF correctly, preserving the overlapping segments. The geometry changes only when the file is loaded in Rhino.
Steps to reproduce:
  1. Open the attached DXF_Import_Unwanted_Diagonal.dxf in Rhino.
  2. Examine the lower-left portion of the outline.
  3. Compare it with the original geometry and the attached Rhino screenshot.
Source DXF inspection:
  • Handle 38D2 is an open LWPOLYLINE with 27 vertices.
  • Its first four vertices follow A → B → A → C:
    A = (27909.6, 25451)
    B = (27909.6, 25478)
    C = (27915.6, 25451)
  • A → B → A forms an overlapping, self-retracing segment.
  • The source contains the horizontal segment A–C.
  • The source does not contain the diagonal B–C.
  • Handle 38D3 is a separate closed, two-vertex LWPOLYLINE.
Actual result:
In Rhino, horizontal segment A–C is missing and diagonal B–C appears. The result resembles skipping the repeated A vertex, although the internal cause has not been confirmed.
Expected result:
Preserve the original segment geometry, including overlapping and self-retracing portions, as AutoCAD and Adobe Illustrator do.
I am not requesting duplicate removal or automatic cleanup. The issue is that opening the file changes its shape and creates a connection that does not exist in the source.
Could you investigate this DXF import behavior?
System information:
  • Rhino 8 for Mac: Version 8 (8.36.26293.11002, 2026-10-20)
  • macOS Tahoe 26.6.2
  • Mac mini with Apple M2 Pro
  • DXF_Import_Unwanted_Diagonal.dxf
  • Screenshot showing the incorrect geometry in Rhino
DXF_Import_Unwanted_Diagonal.dxf (1.2 MB)
