Hi folks (and especially @Helvetosaur ),
Going crazy here trying to get a DXF file over to a laser cutter that has an antique controller (ANCA built in 1982!!!)
Not surprisingly, they can only read lines and arcs. That’s not an issue as I can fiddle around with Convert settings to get a file that is not too heavy but is close enough to the original design.
The problem is that I cannot get a file out where all of the lines and arcs are joined. The Laser cutter shop gets all of the segments as unjoined. If I import the file back into Rhino, the sections are indeed not joined anymore.
Any suggestions for a DXF export setting that will do the trick? I’ve run out of ideas and I’m usually pretty good at this stuff as I create cutting files for CNC all day every day.
Thanks, Steve
