DWG import multiple copies of blocks in file
When I import a DWG I get a lot of copies of the same blocks in the file. Does this something have to do with how the file is exported from my client or does it something have to do with the way I open the file? Some files don’t have this issue and others do.
TP1275-BA-608-609.dwg (1.8 MB)
Rhino 7 SR30 2023-5-10 (Rhino 7, 7.30.23130.11001, Git hash:master @ 92e6bbd255ee28a4168ed9e8d38a590062283b45)
License type: Commercial, build 2023-05-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 12-22-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.02
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-22-2022
Driver Version: 31.0.15.2802
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.30.23130.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.30.23130.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.30.23130.11001
C:\Program Files\Rhino 7\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.30.23130.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.30.23130.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.30.23130.11001
Hi Tom -
I opened that DWG file in both Rhino and Autodesk DWG TrueView 2023 - both warn of missing referenced files:
Rhino:
DWG TrueView:
There’s some clipping of blocks that Rhino doesn’t support, but, apart from that, those appear to be the same.
Your screenshots show something else but that might be because referenced files are found on your disk somewhere.
DWG TrueView is free, so you could use that to verify the contents of DWG files that are sent to you.
OK, thanks for the explanation.
