Dwg import brings "donuts" instead of original pipe-elbows
I’m trying to import a dwg file containing pipes using 45° elbows
Both in rhino 7 and 8 the import transforms the elbows into donuts (loops).
PipeElbow.dwg (29.6 KB)
Any ideas to solve this?
Best
Sebastian
Explode and retrim the surfaces.
Hi Sebastian,
I opened up a ticket for the dev to take a look at this. Thanks for reporting.
https://mcneel.myjetbrains.com/youtrack/issue/RH-86368/Autocad-Solid-geometry-imports-as-open-Surface
Hi @sebastian.duque,
Can you please attach a dwg file that has just one of the two problem objects and nothing else? It will simplify debugging knowing that the only object in the file is the one we want to dig into. Also, is the DWG file from Rhino or some other source?
Thanks.
Tim
Hello Tim,
Thank you for your interest.
The dwg comes from an export from TopSolid.
The geometry in TopSolid is modelled as a solid bar along a line, then emptied inside using 1mm thickness.
Attached the dwg file in which the only geometry is this elbow:
This are the import settings I’m using:
Best regards,
Sebastian
(attachments)
PipeElbowIsolated.dwg (19.9 KB)
