DWG Compatibility Settings
I have a DWG file that won’t open in Rhino. I want to work with this file using both CorelCAD and Rhino so DWG or DXF formats should work. It opens in Corel CAD successfully.
I have the files attached in a link. It’s pretty large. Will someone help me with knowing proper DWG settings for Rhino? Thank you.
https://1drv.ms/u/s!AmEW-HsXOJs0u2g2CWb8Mr0923P4
Both the DXF and DWG seem to open fine here in Rhino 6 using these (default) settings:
(Only tested on Win at the moment…)
Yeah that worked! Thank you, Wim.
