Survey_2023.07.08_Building.dwg (489.9 KB)
I have been receiving surveys as DWG files and need to import them into Rhino 8.
I noticed Rhino is “skipping” all the information in the attached DWG file.
The file include 2D polyline entities describing building contours and roof tops.
The information will import correctly after exploding the 2D polylines in lines, which is useless for me.
The source of the data was generated in Autocad, and I extracted the problematic entities using BricsCad, which has been rock solid in all my DWG related work for the last 10 years.
Hi @Gil_Rosenthal,
Thanks for the file.
I see the issue.
I have logged: RH-83817/DWG-not-importing
We will let you know here where there is a fix.
Sincerely,
Mary Ann Fugier
Thanks Mary, I will also give this a closer look to see if any other entities get lost in translation.
Sincerely
Gil
RH-83817 is fixed in Rhino 8 Service Release 12
I am blown away by the speed this issue was managed!!! Wow!
