hello
I’m modeling a stairway and i have a couple of many design variations i wanted to model one floor and duplicate the rest. but the problem is that in the grasshopper when i duplicate the geometries via the move component, the materials i applied to the original does not carry over. it tried using match properties after baking which even for objects with more the one material but is there a way to do so in grasshopper either natively or via a plugin?
thanks
Hi!
(Your context suggests you might want to use blocks, by the way…)
To bake objects with materials, natively… nope.
But you can do it with scripts , like c# or such.
or
I never used it, but a lot of people mention Elefront … try it!
For what it’s worth…
Sounds like you want to move/replicate geometry and have it retain attributes (esp. material)?
thanks for the suggestion.
tried Elefront unfortunately it doesn’t have the feature im looking for.
but blocks sound like a great idea
thanks for your response.
yes i have some geometry in rhino with all the materials set up and i want to retain those material when i duplicate those geometries in rhino
