Is there a way to find the surface (from a closed polysurface) that touches the contruction plane and run the command “DupFaceBorder” on it?
I do not want to manually select the surface.
I want a routine that will cycle through the faces and programatically select the surface that touches the construction plane and run DupFaceBorder it.
Could you give me a little more insight as to how this could work? I tried walking through this manually using the command line and when I input “IP” I get and unknown command error.
Version 5 and 6. I have users using both. I did get it to work in 6 and it works well. For Version 5 I may have to construct a temporary surface to use to get the intersection and then delete it. If you have another work around for 5 let me know. Thanks for the help.
