Can anyone help ? Drop down menus are not sticking and it is annoying, every time, i have to use the up and down arrow keys and the the return key to select items in a drop down menu. Using the mouse does not work.
Does anyone has a fix ?
I’m using the latest version of Rhino 7… (7.7…) and the most updated version of Windows 10 Pro.
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Intel(R) HD Graphics P630 (Intel) Memory: 1GB, Driver date: 1-8-2021 (M-D-Y).
Primary OpenGL: NVIDIA Quadro M1200 (NVidia) Memory: 4GB, Driver date: 5-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.59
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-6-2021
Driver Version: 27.21.14.6259
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
You should start by load-protecting all non-Rhino plug-ins (Tools > Options > Plug-ins, plug-ins that do not ship with Rhino. Right-click each plug-in, select lpad-protect.) Once all have been handled restart Rhino. If that works you can load each plug-in one by one and write down which plug-in causes the problem.
Btw, any reason to have that many versions of KeyShot installed?
Also, you don’t need RhinoPbrMaterial, that was a plug-in for Rhino 6. Rhino 7 has Physically Based material that is better.
