Drawing only possible from o-snaps
I can only start any lines from the selected object snaps. If I have deactivated all object snaps, I cannot draw at all. what could be the reason for this? (I use windows11)
Hi Jonathan - is this true in a brand new file with the default views and CPlanes?
What happens if you start the Line command, and you try to set the start point?
