Trying to draw the tread for a stair from 2 points; first, an intersection of a section curve and other a regular step height as a series of lines. When I move the intersection points off the curve to get the riser and draw a line: fine. But to then draw the horizontal back to the curve seems impossible. I tried to shift the list up one to draw the horizontal but all the points have the same index 0.
Thats great, thanks, yes! Knew there was going to be an easier way!
In the end for my method the key thing was flattening. But its great to learn Contour and Connect.
Next challenge will be how to work with it if the curve bulges in the other direction so it has to go down the other side…
