Drawing a Double Parabolic Roof
Hello all,
I’m new to Rhino for Mac so I apologise if this is a very basic question.
I’m trying to model a double parabolic roof something like the attached image. I’d like a true parabolic curve to be along the long and short axis of the roof and the perimeter to be as the lozenge shape shown. I have drawn this from 9 free form curves that have been lofted and then blended. I don’t have access to RHINOMEMBRANE is this needed?
Any help appreciated.
Many thanks,
Paul
(My comments are based on Rhino for Windows.)
The Parabola command draws true parabolas. Parabolas can be non-uniformly scaled using NU and will remain parabolas.
Are you looking for something like this: Parabolic roof DC01.3dm (163.4 KB)
David,
Thanks for your reply.
The model you sent does answer the question but I think I asked the wrong question!
The curves on the model I posted are Splines “S” shapes and this is what I am after so the roof flattens towards the edge. Perhaps this makes makes no difference, what you seem to have shown is splitting into quarters and presumably lofting a segment?
Regards
Paul
I created one quarter using Sweep2 and then used Mirror to create the other three segments. If a single surface is desired the segments could be merged using MergeSrf.
How much have you done in Rhino previously?
Thanks David,
I’m a complete novice as I’m sure is apparent.
This is a sketch of what I am trying to do.
Thanks
I don’t know how precisely the model have to be but for that sketch, you can model it by revolution and then, scale 1 dimension to get it longer like the AA section.
Your curves are not parabolas.
You might want to take time to go through the online Rhino for Mac tutorials. https://www.rhino3d.com/tutorials
