Hi, I am trying to draw a spiral with a constant slope on top of a sphere, I am encountering an error with rs.vectorAngle which I can’t manage to solve (to keep my script going clockwise along the sphere). Can anyone help or letting me know what I am doing wrong?
this is the procedure:
- The script starts by getting user inputs: the step between contour lines, a sphere object, and a set of curves.
- It calculates the center of the sphere and sets the initial radius of the contour circles.
- The script starts processing curves from a specified index. It begins by getting the starting point of the first curve.
- It creates a circle at the starting point and calculates a vector from the center of the sphere to this point.
- Then, it iterates through the remaining curves. For each curve:
- The script copies the curve downward by the specified step.
- It finds intersection points between the circle and the new curve.
- Calculates the angle between the original vector and the vector to the intersection point.
- Decides whether to add the first or second intersection point as the new point based on the angle.
- Creates a new circle at the new point’s location and moves it up by the step.
- The script accumulates all the generated points in a list.
- Finally, it creates a curve through all the points, generating the contour line.
this is the script
# Get the step between contour lines from the user
step = 1 #
rs.GetReal("Insert the step between contour lines")
# Get the sphere object and curves from the user
sphere = rs.GetObject("Select the sphere", 8)
curves = rs.GetObjects("Select curves", 4)
# Calculate the center of the sphere
center = rs.SurfaceAreaCentroid(sphere)[0]
# Define the initial radius of the circle
circleRadius = 4
# Set the starting index for processing curves
index = 23
# Get the starting point for the contour creation
point = rs.CurveStartPoint(curves[index])
# Create the first circle at the starting point
circle = rs.AddCircle(point, circleRadius)
# Calculate the vector from the center of the sphere to the starting point
vector1 = rs.VectorCreate([center[0], center[1], 0], [point[0], point[1], 0])
# Initialize the angle variable
angle = 0
# Store the points that will form the final contour
allpoints = [point]
# Loop through the remaining curves for contour creation
for i in range(index, len(curves) - 1):
# Copy the current curve downward by the specified step
newcurve = rs.CopyObject(curves[i + 1], [0, 0, -step])
# Find the intersection points between the circle and the new curve
intersect = rs.CurveCurveIntersection(circle, newcurve, 1)
newpointcoord = intersect[0][1]
# Calculate the vector from the center of the sphere to the new intersection point
vector2 = rs.VectorCreate([center[0], center[1], 0], [newpointcoord[0], newpointcoord[1], 0])
# Calculate the angle between the two vectors
newangle = rs.VectorAngle(vector1, vector2)
# Determine the direction of the new point based on the angle
if newangle > angle:
newpoint = rs.AddPoint(intersect[0][1])
else:
newpoint = rs.AddPoint(intersect[1][1])
print("other dir")
# Update the angle variable and create a new circle
angle = newangle
circle = rs.AddCircle(newpoint, circleRadius)
# Move the circle upwards by the specified step
rs.MoveObject(circle, [0, 0, step])
# Add the new point to the list of all points
allpoints.append(newpoint)
# Create a curve through all the generated points
rs.AddCurve(allpoints)```
[spiral input.3dm|attachment](upload://pSTWtxbmPxzZSrDTt6414aAwCKV.3dm) (267.3 KB)
