Draw the wire dynamically between components with c#
Hi all, if you please anyone can help, I want to Draw the wire programmatically between multiple components with C#.
From an IGH_Component, you can access the outputs as IGH_Param object with Params[i] property.
Then you have the AddSource(IGH_Param) method that you can use on another component’s inputs params.
This would need to be triggered by an event or scheduled in a new solution.
Without more context (or better, some code) it will be hard to be more helpful.
Hi Magicteddy,
I would like to thank you for your answer, its working now.
