dk2079
#1
currently in Rhino 6 latest build, I can only see the correct draw order it set on objects in wireframe mode.
If I switch to any other mode the order of lines hatches etc is lost which is really annoying.
I believe this was working different at some point before.
Can you confirm and/or clarify if this is an intended behavior?
thanks,
Daniel
pascal
(Pascal Golay)
#2
Hi Daniel - that is certainly not expected behavior as far as I know. Is this consistent for you, even in a simple test file?
dk2079
#3
yes, consistent and in any even so simple file:
here all objects with cleared draw order:
wireframe:
shaded:
here hatch and black rectangle with “bringToFront”:
wirefarme:
shaded:
dk2079
#4
file attached!
drawOrder.3dm (29.3 KB)
pascal
(Pascal Golay)
#5
Hi Daniel… thanks, looks correct here… I guess, let’s have a look at the output from the SystemInfo
command…
dk2079
#6
here we go:
Rhino 6 SR22 2020-1-28 (Rhino 6, 6.22.20028.13281, Git hash:master @ 379871ece695dc096e83826f08b429db8ca2e7f5)
License type: Educational, build 2020-01-28
License details: Cloud Zoo. In use by: Daniel ()
Windows 7 SP1 (Physical RAM: 48Gb)
Machine name: KRAKEN
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX TITAN X (NVidia) Memory: 12GB, Driver date: 1-29-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 442.19
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-29-2020
Driver Version: 26.21.14.4219
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.22.20028.13281
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\ColorPicker (336da4ab-03d3-42ca-b1fb-313bfd4c1157)\2019.2.15.811\ColorPicker.rhp “ColorPicker”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Next Limit\Maxwell for Rhino\maxwell_rhino.rhp “Maxwell for Rhino” 5.0.6.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.22.20028.13281
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.22.20028.13281
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.22.20028.13281
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\SectionTools (fbdb1d7f-8cfb-42c1-9858-87cb6315932c)\2019.2.19.478\SectionTools.rhp “SectionTools”
pascal
(Pascal Golay)
#7
Hi Daniel - if you have not, can you please try reverting one or more of the ‘non-working’ modes to defaults?
dk2079
#8
Hi Pascal,
thanks, yes, I tried with shaded and it fixed it.
But I can’t do that with all my custom created modes… any suggestion what could be done to fix these without resetting?
pascal
(Pascal Golay)
#9
Hi Daniel - can you post or send me an ini file with a non-working mode? (Options > View > Dispay Modes > Export)
dk2079
#10
sure, for example:
FlipMode.ini (11.5 KB)
pascal
(Pascal Golay)
#11
Hi Daniel - thanks - I see the problem here and I have not yet pinned down the culprit setting…
dk2079
#12
thanks for checking… I guess that can be tedious, but I hope some display pipeline programmer can give hints where to look at…
dk2079
#13
I think ambient occlusion breaks it.
*shadows, to be precise
