I rendered surfaces that are on the same level on top of each other, and I want the grass rendering to be above the flooring without changing its level, is there a draw order for rendering that I can use? or what can I do?
AFAIK, there is no other way than to move your grass patches the slightest amount up, say 0.001 units.
Or trim a hole in the deck. You can untrim later if needed.
