Draw lines between two curves and automatically dimension them every 100m
I want to automate the process of drwaing one line every 100units to find out the distance between the two lines every 100units, the distance must then be dimensioned.
Is there an easy way to do that?
Top curve has a name : limits1
Bottom curve has a name : plate1
I am working in Python script, but RS is fine.
I need a command like CRVDEVIATION but that will measure the distance between the two curves every 100mm, guys I really need your help please
