How to draw everything infront? Right now everything is drawn on the C-plane. I want my drawing to be infront of everything.
I mean parallel to the closest edge.
Hi Mohan,
I’m not sure what you mean, but you could you could use the _Align command in one of the views.
Andy
It’s probably easier to just move the Cplane to your desired drawing location. There are a lot of good commands for doing this under the CPlanes toolbar.
Since you have Planar turned on, you could use any Osnap to start the drawing at the front-most feature and the rest of the drawing will be on that plane.
I used look at surface and C-plane to view. That worked. Thanks!
