Draw Half_circle
Hi
the attached Python_Script draw a half _circle and i share it.
# This Python script draws a half circle dynamically
# Autor  ing. Carlotto Vittorio  carlottovittorio@gmail.com
# 10-10-2013   Bassano del Grappa  Italy
#-*- encoding: utf-8 -*-
import Rhino
import System.Drawing.Color
import scriptcontext
import math
def half_circle():
    line_color = System.Drawing.Color.FromArgb(255,255,255)
    #cur_lay=rs.CurrentLayer()
    #arc_color=rs.LayerColor(cur_lay)
    position=rs.GetDocumentData("HalfCircle","position")
    if position=="":position="Right"
    options=["Right","Left"]
    position=rs.GetString("Position of Arc <Enter to confirm>",position,options)
    rs.SetDocumentData("HalfCircle","position",str(position))
    stringa=position
    if stringa=="Right":
        rad=-math.pi/2
        angle=-90
    if stringa=="Left":
        rad=math.pi/2
        angle=90
    while True:
        pt_start=rs.GetPoint("StartPoint of half Circle < Enter for End>")  # con metodo script
        if pt_start==None :break
        arrplane=rs.ViewCPlane()
        ZA=arrplane.ZAxis
        def GetPointDynamicDrawFunc( sender, args ):
            #print Rhino.DocObjects.Layer.Color()
            mid_point=(pt_start+args.CurrentPoint)/2
            args.Display.DrawLine(pt_start, args.CurrentPoint,line_color,1)
            vect_l=pt_start-mid_point
            Rhino.Geometry.Vector3d.Rotate(vect_l,rad,ZA)
            p3=Rhino.Geometry.Point3d.Add(mid_point,vect_l)
            arc=Rhino.Geometry.Arc(pt_start, p3,args.CurrentPoint)
            args.Display.DrawArc(arc,arc_color,2)
        gp = Rhino.Input.Custom.GetPoint()
        gp.DynamicDraw += GetPointDynamicDrawFunc  # chiamo in continuo la funzione che mostra le curve dinamiche
        gp.Get()
        if( gp.CommandResult() == Rhino.Commands.Result.Success ):
            rs.EnableRedraw(False)
            end_point= gp.Point()  # qui ho le coordinate del punto del mouse
            mid_point=(pt_start+end_point)/2
            mat_rot=rs.XformRotation2(angle,ZA,mid_point)
            p3=rs.PointTransform(pt_start,mat_rot)
            arco=rs.AddArc3Pt(pt_start,end_point,p3)
            rs.EnableRedraw(True)
half_circle()
Ciao Vittorio
Disegna_Mezzo_Cerchio_Dinamico_reverse.py(2.4 KB)
Nice Vittorio! I really need to dive into this dynamic redraw stuff…
Ciao, --Mitch
Hi Mitch
I wish could enter the distance of the line in the loop but do not know how to do.
Can you or @steve help me?
Ciao Vittorio
Hey Vittorio,
I really don’t know much about this stuff… But I stole a couple lines out of one of the examples and if what you are looking to do is to enter a diameter after the first point, the attached should do it…
        #I added these three lines shamelessly stolen from Steve's Get Line example
        #User can enter a number to constrain the diameter
        gp.SetBasePoint(pt_start, False)
        gp.SetCommandPrompt("Pick point for end of semicircle")
        gp.DrawLineFromPoint(pt_start, True)
–Mitch
DynamicDrawSemicircle.py(2.7 KB)
Here’s my tweaked version with command line options for fixed lengths and side
import Rhino
import math
def compute_arc(start, end, length, side, zaxis):
    current_point = end
    if length>0:
        direction = end - start
        line = Rhino.Geometry.Line(start, direction, length)
        current_point = line.To
    mid_point = (start+current_point)/2
    vect_l = start - mid_point
    rad = side * math.pi/2
    angle = side * 90
    Rhino.Geometry.Vector3d.Rotate(vect_l,rad,zaxis)
    return Rhino.Geometry.Arc(start, p3, current_point)
def half_circle():
    line_color = System.Drawing.Color.Black
    side = 1
    if scriptcontext.sticky.has_key('side'):
        side = scriptcontext.sticky['side']
    while True:
        pt_start=rs.GetPoint("Start point")
        if not pt_start: return
        current_layer=rs.CurrentLayer()
        arc_color=rs.LayerColor(current_layer)
        ZA = rs.ViewCPlane().ZAxis
        length_option = Rhino.Input.Custom.OptionDouble(0, True, 0)
        side_option = Rhino.Input.Custom.OptionToggle(side==1, "Right", "Left")
            current_point = args.CurrentPoint
            length = length_option.CurrentValue
            if length>0:
                direction = current_point-pt_start
                line = Rhino.Geometry.Line(pt_start, direction, length)
                args.Display.DrawDottedLine(current_point, args.CurrentPoint, line_color)
            args.Display.DrawLine(pt_start, current_point, line_color, 1)
            arc = compute_arc(pt_start, args.CurrentPoint, length, side, ZA)
        gp.AddOptionDouble("FixedLength",length_option)
        gp.AddOptionToggle("Side", side_option)
        while gp.Get()==Rhino.Input.GetResult.Option:
            if side_option.CurrentValue: side = 1
            else: side = -1
            scriptcontext.sticky['side'] = side
            arc = compute_arc(pt_start, end_point, length, side, ZA)
            scriptcontext.doc.Objects.AddArc(arc)
            scriptcontext.doc.Views.Redraw()
half_circle()
Hi Steve and Mitch
Many thanks for your help.
Ciao Vittorio
@stevebaer
Ciao Steve
The script half_circle is Ok but d’ont pay attention to ortho(F8) and direction constraint (Tab key) .
That function should i to use?
Ciao Vittorio
You just need to set the base point so the GetPoint knows about it.
It’s a solution , thanks
Ciao Vittorio
