Elevation - Dimensioning
Hello together,
I wanted to ask you if there is a solution for height measurements in Rhino. Unfortunately this function does not exist (yet)…
Thank you very much.
Many greetings
Boris
Hello together,
Many greetings
Boris
Hi Boris -
In plain Rhino you can create a point object at the tip of such marker and use the PointCoordinate
text field to display the z-value of that point.
Hi Boris - DimOrdinate
should help here - is that what you are looking for?
Thank you very much! The DimOrdinate command helped me. Is there a tutorial that it looks like in the picture?
Many greetings
Boris
Hi Boris - I do not see a way to get them to have the same appearance as in your image, but I do think that perhaps negative numbers should be supported, as in your image- so far I do not see a way to do that.
Thank you very much. I will design a graphical + numerical combination as a block definition. This should theoretically work…
Thanks again for your valuable advice.
Many greetings
Boris
