Hi,developers!
I found that when draw annotations,the text height does not changed!What did i miss?
DRAW ANNOTATION.gh (5.5 KB)
Hi,developers!
As I have suspected, the actual drawing method is called before the property is set somehow.
I experimented with using a class field of Script_Instace
, so I could pass the TextHeight
assignment right before the DrawAnnotation()
call. It worked.
So change line 65 to TH = height;
Below line 72 add private double TH;
Above line 89 (now 90) add entity.TextHeight = TH;
