Dragging points issues
there seems a bug that came with api version 2.8.
Dragging points on the model does not work properly. They do not set on the dragged position.
Without more details, it’s hard to reproduce the problem you are experiencing.
I know you built an application starting from this API example: https://jsfiddle.net/ShapeDiver/n0678uzc
I just updated it to the latest released viewer (2.19.3) and it seems to still be working as expected. Please give more information about your issue and if possible create an example where the problem happens.
I found the issue. Thanks for help.
