Drag and dropping files over the WIP does not work at least not always. Is this expected at this point?
EDIT:
When drag dropping from the desktop or windows explorer D&D works. However in my goto file manager Freecommander the D7D works for V5 but not the WIP.
So something is different in how the WIP handles a D&D from how V5 does that.
A .3dm file that when drag droped from the same location ( my filemanager; FreeCommander) works in V5 but not for the WIP
No it’s a “regular run” afaik: as a test if I run the WIP as administrator, indeed I cannot drag and drop from windows explorer.
When I drag drop running in normal mode, I can DragDrop from windows explorer but not from my filemanager.
I do get a [+] icon at the cursor but after that nothing happens.
For a quick test I post the .zip file with the portable (no install) version of free commander. FreeCommanderXE-32-public_portable.zip (7.5 MB)
Just unzip it and run FreeCommander.exe
Navigate to a 3dm file (defaults to desktop) and drag drop it over a WIP instance
I ran this through the debug process and found that Rhino is getting a files dropped message from Windows but Windows is reporting 0 files and a “ERROR_INVALID_HANDLE 6 (0x6) The handle is invalid” Windows error. I’m not sure what can be done about this, it appears that the data being provided by FreeCommander is not formatted in a way that is compatible with the current Microsoft tools. I would suggest contacting the FreeCommander people to see if this is a known problem.
Thanks for your efforts.
I emailed the developer of the filemanager and pointed him to this issue.
As I decided it was a good opportunity to donate to the developer, I found the donation gave access to his 64bit version.
@ Marek Jasinski if you are reading along: The 64bit version did not exhibit the malfunctioning and worked as expected.
